Home > Technical (L322) > TDV8 Not starting and brake pedal will not depress.
Johnmann10
Hello all
I recently got my TDV8 back from the garage having had a new EGR valve and belts.
All good for a week and maybe 150 miles.
This morning the car would not start. Ticking noise, full Christmas tree of warning lights and after a couple of further attempts the brake pedal goes 'hard' and cannot be depressed. Tried again tonight, no joy. No Xmas tree this time, just a blank screen and no ticking noise at all, so starter motor not firing at all, I think.
Previous posts suggest it could be related to the brake pedal, my instincts say it's battery.
My question is how best to get some charge into the car as if it can be started it will save me calling out the recovery guys for the 2nd time in a month.
I see mentions of CTEK chargers, looking online there are several so can anyone advise which I should use? Can I charge the battery in place as removing it seems complicated to a layman like me?
Should I try to jump start?
All advice gratefully recieved.
John
Post #707460 22nd Dec 2024 8:44pm
JW911
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
My TDV8 is on the CTEK in the garage most of the time. Ditto the BMW in fact. It gets plugged into the white tow socket via an adapter. Particularly handy at this time of year as I can fire up the remote heater without worrying about the battery. If you don’t have the tow electrics, you can still hook it up straight to the battery although you’ll obviously have to either wire in the socket or connect it via the clips.
All that said, my first instinct is your battery is goosed so I’d change that as your first port of call. It probably won’t be recoverable with a charger. If you can get enough charge in it to start it, drive it straight to somewhere which will change it. 2012 4.4 TDV8 Westminster
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #707461 22nd Dec 2024 9:00pm
Johnmann10
Thanks for the advice.
I do have a tow bar so that's an option.
It won't hurt to have a suitable charger at home so will try that first.
Post #707462 22nd Dec 2024 9:07pm
JW911
https://www.britpart.com/parts/winching/ba...ors/da1409 2012 4.4 TDV8 Westminster
Post #707463 22nd Dec 2024 9:42pm
Fox889
If you’re going in via the tow socket, make sure you get the right pin connector, 7 or 13.
You asked about C-tek, make sure it’s man enough for these large batteries, from memory a 5.0 or higher is needed. I normally connect mine every few weeks if she hasn’t been out, very handy set up. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #707473 23rd Dec 2024 8:16am
Benji1
Australia
Simple fix for this.
Ive had the same issue in the past with my 4.4 TDV8.
You need to press the brake pedal harder to engage the starting connector.
Simplest of fixes!
Post #707476 23rd Dec 2024 9:29am
Andra
Might want a 10 amp battery charger for the big battery . Ctek are ok I’ve been using them for more than a decade and still going .
Victron chargers reputed to be very good and have an app to connect to the charger via Bluetooth and can set parameters . A 10 amp charger can be set to 5 amps if required for a slow charge .
A 25 amp can give a quick charge or set to 10 amps for a slower charge .
Bluetooth range is short . Can check state of charge remotely . Most have IP rating for dust and splash resitance . Marine version available with better IP rating .
Ctek 10 amp and over can do supply mode if using diagnostic tools . Victron can do supply mode as well .
Post #707493 23rd Dec 2024 12:36pm
Johnmann10
Thanks all.
I charged the battery for a couple of hours, and hey presto, started without issue and again a few hours later.
Drove for 10 mies or so, all well except I have an amber engine warning light, and the date has reverted to 2009, time is incorrect etc.
I assume therefore that there must have been a total loss of battery power at some point? Also that the amber warning light is just because the management is out of sync?
My question now then is should I change the battery (I have extensive history for my 2012 4.4TDV 8 with no reference to a new battery ever have been fitted) as a precaution? Or do I need to get diagnostics to find out why the battery drained in the first place?
Basically, what do I do next?
Is resetting the time etc a garage job or can an inexperienced but competent layman do it themselves?
Sorry that I didn't get to try Benji's fix, that was my kind of home mechanics.
Post #707515 23rd Dec 2024 4:02pm
Happydaze
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Tis the time of year that weak batteries throw their hand in!
Not sure of the spec for a 2012 4.4 but mines a 2007 3.6 tdv8 and have had great success with yuasa batteries from gsf car parts. I have the same battery in 2 other vehicles.
And a ctech (7) charger works great. Has a supply function for testing also. Can be found for approx £100 if you look around. Can clip straight on the battery terminals (no tools reqired) or install the plug in tail, or get the optional longer tail to hide in the grill area.
Chris
Post #707558 24th Dec 2024 9:24am
DrRob
The "Wiki" is your must go-to place on here Thumbs Up
https://www.fullfatrr.com/forum/topic43662.html Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #707566 24th Dec 2024 11:58am
SpitfireS
Germany 2012 Range Rover Vogue SE 4.4 V8 Santorini Black
As far as I know the not starting and the hard brake pedal are unrelated.
There are a few posts about the brake pedal issue, none (that I've seen) with a solution.
When the car does tick over and starts but the info display reboots while starting you can be sure your battery is on it's way out, especially during a cold start after a day or two of not driving. 2012 4.4TDV8
2000 Honda S2000
Post #707572 24th Dec 2024 1:16pm
JayGee
The brake pedal needs servo assistance to be able to comfortably press it down enough to engage the starter safety switch. It only takes 1 or 2 pedal actuations as a result of a no start to drain it. 2012 TDV8 Vogue (L322)
Post #707581 24th Dec 2024 3:19pm
Dtech
England 2011 Range Rover Vogue 4.4 V8 Santorini Black
Just out of interest. If this is the case, how would you be able to start the car following maintenance which drains the vacuum system or on a vehicle that has been standing unused for a long period.
Post #707582 24th Dec 2024 3:54pm
Johnmann10
Thanks all once again.
dead again today, so new battery it is.
One final question. I have AA so the path of least resistance (no pun intended) is to pay them to come and fit a new one for me and presumably sort out the time/date/warning light by doing so.
The recommend 3 x Bosch batteries that range between 95AH 800 CCa and 110AH 920 CCA for just under three hundred quid for the bigger one.
Should I buy the more powerful one, or should I do something else entirely. Having had so little use of the car for the last few weeks the idea of the AA just turning up and getting me sorted appeals.
Have a great Christmas all, and a happy new year.
Post #707583 24th Dec 2024 4:10pm
JayGee
you just have to use more force to push down on the brake pedal than normal. 2012 TDV8 Vogue (L322)
Post #707584 24th Dec 2024 4:16pm
