Home > Technical (L405) > Oxygen sensor replacement
funnyguy1
United States
I have a bad Oxygen sensor in my 2016 L405 and was wondering if the after-market sensors, Bosch etc are as good as the OEM? I also read they recommend replacing them in pairs??They sure are a lot more expensive. Thx in advance!
Post #707388 21st Dec 2024 8:18pm
fisha
Fuel delivery, air flow sensors and exhaust sensors are probably one of the areas that benefit from genuine parts to be honest.
I’ve tried various non genuine in different cars in the past and they’ve often had issues that were fixed by getting the real thing.
Other areas are fine with aftermarket, but fuel/emissions are so accurate that it’s probably worth it in the long run. V8 or else ...
Post #707391 21st Dec 2024 10:17pm
funnyguy1
United States
Thanks Fish, much appreciated!
Post #707393 22nd Dec 2024 12:44am
Kot
Are not most OEM parts made in China ? Several post on here and other marques with owners and dealers waiting for that slow boat! 2018 SE SDV8 4.4 Byron Blue
Post #707405 22nd Dec 2024 10:49am
fisha
Re-reading the op, regarding aftermarket part brands, as long as you could be satisfied that a part is genuine Bosch, then it’s is probably one brand which I would think is likely to be OK as an alternative. I was speaking more about the brands which you’ve not likely heard of . V8 or else ...
Post #707437 22nd Dec 2024 2:38pm
funnyguy1
United States
Hi Fish, I installed the new OEM oxygen sensor bank 2 sensor 3 which was very easy but was wondering how many sensors the 2016 l405 has? I have read 4 and 6??
Post #708386 5th Jan 2025 6:21pm
fisha
There are normally sensors each side of the catalysts to measure the cat is doing its job. So iirc each side will have a cat downstream of the headers.
Not sure about other engines though. V8 or else ...
Post #708396 5th Jan 2025 8:13pm
Gremlin500
I found this in the WM above, for the V8 petrol, I would think its the same for all engines?
 “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #708414 5th Jan 2025 10:33pm
