Home > Technical (L405) > FBH - Timed
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
FBH - Timed
Hello,
I always thought my FBH didn't run for long. I set it off either by the remote in the App or directly from the panel. I have even set a timer for the morning in the car.
I set it off tonight by pressing the Heat Now button in the car. I could then see how long it ran for. It was 5 minutes. The air inside the car was cold. Also, touching the pipes, the coolant didn't seem to have warmed up much.
How long should it run? I have hear it running. I feel the pump going for the water. I can feel it taking in air through the intake.
Kind Regards
Iain SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #707049 16th Dec 2024 6:28pm
Dolphinboy
mine is super good, running for c. 25 mins and getting really warm inside. may be the switch over valve syndrome which affected the L322?
Post #707054 16th Dec 2024 7:40pm
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
OP, mine was exactly like yours, didn’t run for long (tested it at 8mins run time) and blew cold. I persevered with programming it to come on, on a few cold mornings and it gradually got better, now it is as intended. Not sure if they all just need a bit of use to get things ‘flowing’ properly First time FFRR owner
Post #707075 16th Dec 2024 10:55pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
Re: FBH - Timed
I believe it should run for 30 minutes. Unless another condition stops it early, such as low battery or low fuel.
Post #707095 17th Dec 2024 1:39am
luxmoggy
I will try this evening. I will connect the battery charger (to make sure). I use it a few times during the year, so maybe it never clears as suggested.
I will let people know. there are no errors in the gap tool. SDV8 AB MY 2020
Post #707097 17th Dec 2024 6:46am
luxmoggy
So, with the battery on the charger, I ran the FBH to warm the car, and it ran for 30 minutes. The voltage is never high enough. I will try again in the next few days without the charger connected. SDV8 AB MY 2020
Post #707152 17th Dec 2024 7:43pm
luxmoggy
So I try this afternoon. So for me I only get timed heating. If the battery charger is connected. I replaced the battery a couple of years ago. It seems ok.
Maybe I can look at the lithium battery from another thread. SDV8 AB MY 2020
Post #707302 20th Dec 2024 4:59pm
