Home > Maintenance & Mods (L322) > l322 4.4 tdv8 - mechanics can't solve the puzzle - egr dpf
Page 3 of 3 <123
kevinp
Yes, that's just as it should be. Thumbs Up
Post #699733 7th Sep 2024 10:23pm
JayGee
The spring is working but the sealing cap under it may not be doing it's job as like mine they go hard over time. I removed the spring and permenantly plugged the hole with a snug fitting self tapping screw and some PTFE tape. The housing doesn't drain when you do a filter change so you just need to suck a bit out before you swop the filter. Looks like you have a leak around the throttle seal ( the green ring in the elbow) which is a common problem as the OE design is poor and many people add additional O rings infront of it to get a better seal. 2012 TDV8 Vogue (L322)
Post #699751 8th Sep 2024 10:05am
Scot44
Scotland 2011 Range Rover Vogue SE TDV8 Buckingham Blue
I just scratched an itch and bought a 2011 4.4TD last month from a guy in London which has done 80k miles. I thought the £15k of engine refurb work including new turbos in recent years was a good thing, but "DPF full take me to a dealer" and limp mode has spoilt the party, just 20miles into a 480miles journey home! TBH the seller turns out to have disappointingly been a geezer. I have been following Georgi's story and feel like I am following him the same rabbit hole (Is your car going OK now? No conclusion in the thread!). My local mechanic who has a Disco4 with EGR/DPF delete said it was reading 67g soot Shocked but he got it down to under 2g. He thought a kinked pipe to DPF could have been the problem. It was fixed, but then 5 miles into a 350mile journey this week the message was back. I just checked the MAF and it looked horrible so the inside of the donut must be the same. The elbow pipe also seemed a bit loose but I dont know if this is enough to cause excess sooting (I cant upload the video). The car goes back to the mechanic tomorrow. What should he be doing according to collective wisdom? High pressure smoke test seems starting point. I definitely want him to clean out the donut too, but what after that? Is the turbo drain modification highly recommended'? 2011 4.4 V8TD Vogue SE
2020 Alpina B3 Touring
1993 Saab 900T16 S Convertible
1993 Saab 900T16 S Hatchback
Post #706392 8th Dec 2024 2:57pm
JayGee
High pressure smoke test and read any fault codes. Donut cleaning is not going to fix anything to do with this issue neither is the turbo drain mod but certainly check the oil filter drainback valve. 2012 TDV8 Vogue (L322)
Post #706393 8th Dec 2024 3:20pm
Georgi
Bulgaria 2011 Range Rover Autobiography Black 4.4 V8 Barolo Black
Thank you all that contributed to this puzzle. At the end after nearly 4 months of tests I resolved to removing the dpf. I did my best effort with the limited time and not having a scan tool myself relying on several mechanics that could not diagnose the issue. Now I am driving the car with pleasure but with a little bitter aftertaste of a failure Wink But whatever, love the car, thank you all. l322 2011 4.4 TDV8 Autobiography Black
l322 2007 3.6 TDV8
Post #707026 16th Dec 2024 12:20pm
Page 3 of 3 <123
