Home > Technical (L460) > Wheel change from 23 to 21 inch - what is this part for?
Freddy Bear
Hello all,
With winter coming and another trip to the Alps looming I thought I would run some smaller wheels. So today I changed from the 23 inch ones in the first picture to the 21 inch ones in the second - which are the wheels Land Rover are running on the EVs they are testing in the Middle East.
I checked you can specify these wheels on my L460 LWB 7 seat and you can (you can even go an inch smaller).
When the changeover was being done we quickly found that although the smaller wheels went on fine they didn't rotate freely thanks to a small block - see picture. It was not serving an obvious purpose and was held on by one screw so we removed them from the two front wheel areas and the 21 inch wheels now run freely. Driving home, aside from a smoother ride, I couldn't detect any other differences.
All the mechanics at the garage (not LR) looked at the part and none of them or me could figure out what it does. The parts are marked BB. Do you have any ideas?
Post #706720 12th Dec 2024 6:48pm
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
It’s a mud scraper.
Post #706721 12th Dec 2024 7:17pm
Japseroony
England 2019 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Mud scraper available in several sizes depending on the wheel size- you may need the shorter option if fitting 21” rims Thumbs Up "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #706780 13th Dec 2024 2:32pm
