Home > Technical (L460) > Cabin Pre-Conditioning Option
TMO53
I'm wondering if anyone else on this forum has experience with this option on the L460.
On our old L405 there was a little 'key fob' which, when pressed, started the fuel burning Auxiliary Heater under the bonnet and 15-20 minutes later the interior of the car was toasty warm (along with defrosted windscreen, etc.). Which meant getting in the car on a cold morning didn't require a duvet jacket for the first 5 miles.
As a result I paid the significant amount for this option on our new L460 only to find that it doesn't appear to warm the cabin even though the info on the website promises 'Your journey begins when you want it to and how you want it to. Pre-heat or pre-cool the cabin from your phone, without starting the engine or getting in the vehicle.' Apparently, according to the dealer, this option only pre-conditions the coolant in the engine so the car warms up fast once you set off. The iGuide seems to confirm this and doesn't talk about Pre-Conditioning at all apart from in the PHEV (which this option is available for).
Are there any owners out there who can confirm that the option only preconditions the engine or whether I've got a faulty auxiliary heater that needs sorting. The current list price of this option is £1275 (in the UK) and I can't imagine anyone spending that kind of cash if it doesn't directly warm the car.
Post #705818 1st Dec 2024 11:16am
JackRegan
I have the P550e, so no diesel heater but it has the Climate option in the Remote App which conditions the cabin and preheats it to 21.
I've used it a few times now. It did clear the ice from the screens, and the inside, I would describe it as "it took the chill off" rather than being "toasty," like my L405 would get from a 30-minute warm-up.
I've been meaning to read up on it, but the wife keeps finding alternative things for me to do, so also interested in hearing from others' experiences. 2024 P550e Autobiography
2016MY TDV6 Autobiography - Gone
2011MY 5.0 SC Autobiography Black - Gone
2005 TD6 Vogue - Gone
Post #705832 1st Dec 2024 3:15pm
DJIT
My experience:
I open the In-Control app on the phone. Press the remote icon on the bottom of the screen. Press the plus or minus button to adjust temp (second highest setting is 28 degrees, highest setting is "hi"), press the fan button on phone screen for a few seconds. P550e remotely starts the petrol engine from the app and car starts conditioning / heating.
As it starts the engine and not just a heater you should only do it when the car is outside.
The doors remain locked and the lighting doesn't come on.
As soon as you get in the car the lights and dash come on and as you drive away the engine switches off and returns to EV mode.
Post #705919 2nd Dec 2024 4:31pm
JackRegan
Interesting.
I am using a Pixel phone.
The app for my wife Jaguar, has the + and - to adjust the target temperature.
but my Range Rover doesn't.
Post #705926 2nd Dec 2024 5:32pm
TMO53
For comparison, here is a screen shot of my D350 L460 iPhone app.
Where it shows a small chevron next to ‘Climate’ that enables a ‘pull down’ to select between the Auxiliary Heater and starting the car engine to warm the car. However, one should be aware that running the engine in an unattended vehicle on the highway is an offence in the Road Traffic Act so it’s not advisable to do this if your car is parked at the side of the road (but it’s ok on your drive).
Post #705928 2nd Dec 2024 6:00pm
DJIT
I think I’ve just Worked it out.
Go to the top left where it says “climate”.
Click on it and a drop down box appears.
It gives you two options “engine climate” or “electric climate”.
If I were a betting man I’d wager mine was set to engine and yours was set to electric?
Post #705930 2nd Dec 2024 6:21pm
JackRegan
Spot on!
Thank's DJIT, you're a star, that was it !! 2024 P550e Autobiography
Post #705936 2nd Dec 2024 6:40pm
Westminster
Pre heat should work on either of the options from the drop down list though shouldn't it?
On my '23 P530 non-hybrid it has Fuel Operated Heater option (no temperature selection) that heats the cabin with the engine off (and does a very good job of it) or the "Engine Climate" option that starts the engine and you can select the temperature.
Post #706360 7th Dec 2024 11:46pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
If it doesn’t work on the electric side then your HV heater has failed. See my recent post about symptoms etc. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #706381 8th Dec 2024 10:38am
JackRegan
For me.
Preheat works in EV mode, but, there is no option to increase the preset temp of 21c. On a cold day, whilst this warms the cabin, I find 21c doesn't 'Butter the Parsnips'.
Preheating using ICE allows me to increase the temperature to a much more comfortable level.
So I think (hope), mine is working as intended and has not failed. Interestingly there isn't a water temp gauge on the L460, or at least I haven't found one.
Reading your other thread, out of interest, would the temp gauge, by staying low indicate the EV mode isn't heating the coolant as intended? 2024 P550e Autobiography
Post #706382 8th Dec 2024 10:56am
chicb
United Kingdom 2018 Range Rover Autobiography TDV6 Barossa
Thanks for that. Mine was set to electric. I have a PHEV but when trying the engine setting its telling me it can't work as the cable is connected & switch to electric climate. The cable is not connected??? Big Cry
Post #706386 8th Dec 2024 11:33am
Phil.
The OP is asking about the Fuel Operated Heater (FBH).
I have a FBH fitted and it works fine. On previous models, not heating sufficiently was due to a lack of battery power and the FBH stopped heating before the normal 30 mins maximum. MY23 D350 HSE
On my 7th RR plus various other JLR vehicles
Post #706411 8th Dec 2024 5:52pm
TMO53
Thanks to everyone for their contributions on this subject.
Recent use of the Cabin Pre-Conditioning feature suggests that it does appear to be working slightly better albeit not as well as our old L405. Maybe the latest software update (OS 4.2.1) has improved its operation as it appears to make some changes to the AC system.
Everyone have a great Christmas.
Post #706470 9th Dec 2024 12:37pm
