Home > Technical (L322) > Coolant in Oil after Oil cooler replacement and EGR Rebuild
edward19
Hi All
I'm in a bit of desperate need of help. Having replaced the oil cooler and rebuilt the EGR unit on my 4.4TDV8 I now have coolant in the oil. The coolant doesn't seem to circulate through the engine anymore and I've topped up the coolant multiple times. The temperature gauge in the vehicle shows normal operating but I also have no hot air in the cabin. It appears there is a significant and uncontrolled contamination of coolant in the oil. Does anyone have any idea what i might have done wrong?
Many thanks
Edward
Post #706235 6th Dec 2024 11:03am
toby1
Not hot air in the cabin is usually the valve on the RH inner wing. Plenty of info on it here.
Does the header tank still have residual oil in it from before the oil cooler replacement? If so, replace it (about £50 and under an hour DIY). 2012 Vogue TDV8 in Aintree green over sand
Post #706263 6th Dec 2024 2:56pm
edward19
Many thanks for the advice. In the end it was me having a moment. When I removed the old cooler some coolant went into the sump. I've since drained the oil and refilled, including topping up the coolant. Now it all appears ok with hot air in the cabin too. What a mission.I have a tiny seep of coolant from one of the thermostat hoses but that is a job for another day after todays panic.
Post #706264 6th Dec 2024 2:59pm
Eastsoutheast
United Kingdom 2012 Range Rover Vogue TDV8 Santorini Black
Awesome news, congrats on the positive outcome.
Out of interest would you say replacing the oil cooler is a straightforward job for a non mechanic as its something I would like to do myself as preventative measure. 2012 4.4 TDV8 Vogue Santorini black ivory leather
Post #706271 6th Dec 2024 3:42pm
toby1
I've recently done it, and the thermostat housing.
Knowing what I know now, it could be done in a day with all the parts to hand. I would recommend replacing coolant hoses while you have the access, especially the EGR one on the left of the cooler. See my RR thread for more info. Also there are a few YouTube videos which can assist.
Where I messed up was breaking the connector to the fuel pressure sensor. Don't do that. 2012 Vogue TDV8 in Aintree green over sand
Post #706307 7th Dec 2024 9:59am
