Home > General (L405) > Park access height feature stresses suspension, transmission
lambo911
United Kingdom 2016 Range Rover Autobiography SDV8 Barolo Black
I use the park access height feature which lowers the car when you park up. I am sure it puts a lot of stress through the suspension joints, transmission and handbrake as the suspension geometry changes with ride height.
It may have something to do with the top knuckle joint snapping which often seems to occur when the car is being parked.
I have started pressing the lower button whilst the car is in neutral with the brakes off so I roll it forward slightly to let the tyres settle. Then I put it in park and apply the handbrake.
Anyone have any thoughts on this? 2016 AB SDV8 Barolo black
Post #705822 1st Dec 2024 1:13pm
if and when i use it i make sure i have at least a cars length to go 'down' and at a slow speed..
it certainly does strain a bit when you go into access when stationary.. ... - .- -.
Post #705823 1st Dec 2024 1:27pm
CS
Like you I thought this would put needless strain on the system and so I switched off the auto lower to access height feature when I got the car and have only used it on the rare occasions that I need to drive people who struggle to get in/out at normal height. I have operated it with the car stopped on those occasions.
I do move the car from normal to high and back regularly, when entering/leaving fields and tracks, the car is generally moving when I do that. Only Range Rovers since 1988
Post #705866 1st Dec 2024 8:58pm
Gremlin500
Sorry chaps, Total Bunkum:
Why design and develop and deliberately configure a car with “Auto Access Height” in that case?
Also, not exercising the suspension by leaving it in the one position is detrimental to the airbags, of which replacing all four is seriously expensive compared to a few rubber bushings, which are wear parts and have to be replaced every 6-8 years anyway!
Twisted Evil “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #705872 1st Dec 2024 9:24pm
lambo911
When you lower the car it pushes the bottom of the wheel out and also the top of the strut in.
I am sure the designer factored this strain in however it will put a load on the top of the strut, and when you consider a wide tire on a sticky surface that can be quite high.
It has to be better if lowering and raising is done with some sympathy for the old joints Very Happy 2016 AB SDV8 Barolo black
Post #705909 2nd Dec 2024 3:00pm
Gremlin500
Ahem, some “Gremlins’ Advocacy” there, of course Very Happy Twisted Evil
Interesting, so if parked on say gravel or mud or sand, could an observer see the wheels move axially?
Of course, no matter what prudent measures you take to avoid wear & tear in one place on the fullfat, you will probably be damaging something somewhere else……. Rolling with laughter
Certainly the Steering joint bellows frequently fail, -open the bonnet then have someone exercise the suspension, to see how much its articulation changes.
Another well-known example is the Auto Steering Column Control function, which raises the steering wheel and lowers the drivers’ seat to assist exit: -apparently, it’s a big no-no to use that function as well. Fortunately, I’m not portly enough to need that anyway, but I’m working on it! Rolling with laughter “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #705914 2nd Dec 2024 3:32pm
Totally agree, I can't see it would put any significant stress on anything....
I have to manually do it but I always drop it to access to give the suspension a work out, I also use off road height, low box and HDC regularly to keep them working as they should.... Then I'm sad and exercise things like the rear seats and windows which just don't get used, there are plenty of other bits as well...
Use it or lose it seems to apply.... Thumbs Up Pete
Post #705981 3rd Dec 2024 11:16am
Gremlin500
Yes, imagine the stress on the suspension when negotiating a tight turn a little too quickly, hitting a pothole, or in some lairy off-road situation? Lowering the vehicle is a somewhat gentler operation alltogether, so go ahead and enjoy your fullfat, no need to turn everything off! Thumbs Up “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #706003 3rd Dec 2024 1:25pm
