Home > Technical (L322) > 2011 TDV8 4.4 Compressor Rebuild Kit |
TomC-RRV8 Member Since: 18 Sep 2022 Location: Pangbourne Posts: 75 |
I have bought a kit from https://4x4airseals.com/ great kit and sorted all my issues out has a wide variety of kits available.
2nd Dec 2024 7:38pm |
Benji1 Member Since: 11 Sep 2023 Location: Perth Posts: 22 |
Thanks Tom,
2nd Dec 2024 11:08pm |
Ive taken the cowling off and have taken a photo of what I have seen.
7th Dec 2024 11:44am |
will308f Member Since: 19 Apr 2022 Location: plymouth Posts: 419 |
i had this on my 3.6 58reg it was the seal on the piston that had worn so takes twice as long to get the pressure replaced ....got everything i needed from 4x4airseals ,also replaced the beads as these do break down and turn to dust which gets into the valve blocks |
7th Dec 2024 12:09pm |
What do you mean by the beads? |
7th Dec 2024 1:13pm |
in air dryer there beads that is used to remove the moisture |
7th Dec 2024 1:21pm |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 817 |
email Andrew at 4x4, figure out what make and model air compressor you have first https://4x4airseals.com/product-category/landrover/rangeroverl322 The piston ring fails after a certain period of time - see below http://www.bagpipingandy.com/repairkit.html |
7th Dec 2024 2:41pm |
Thanks for the info Gents.
9th Dec 2024 12:10pm |
