Home > Maintenance & Mods (L405) > Front Cameras
dave the builder
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Front Cameras
Hi, i'm currently trying to see if i can move 1 of my junction view cameras to a more central position on my 2013 ff autobiography, its a march plate and so doesn't come with the front camera, just junction and
and kerb view, so i was thinking of moving 1 of the junction view, which i dont use to a more central position as i need to park right up against a wall so my arse end isn't hanging out. Has anyone ever done this ? or has anyone any advice if this is possible ? any help much appreciated.
Post #705902 2nd Dec 2024 12:22pm
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Sorry to tag on to your thread, Dave. I can't answer your question, but I have minor problem in that the feed from my front camera is upside down, and someone might be able to answer both questions at the same time.
I don't know if it is as simple as someone installed the camera upside down, and all that is requried is a bumper removal and turn the camera around.
Bumper removal video can be found here:
 Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #705908 2nd Dec 2024 3:43pm
Ryanmt
United Kingdom 2017 Range Rover Autobiography SDV6 Santorini Black
2013-2016 had two cameras on the front, 2017 onwards has one.
Mines knackered so I'm gonna replace it this weekend, I'll check if it can be fitted upside down. The camera itself has a notch but not sure about the bumper.
Worth being aware for anyone else replacing cameras, there are shed loads of fakes on AliExpress and eBay. Unless you buy a genuine one from the dealer I would assume you are just paying extra for a counterfeit sticker and packaging!
Post #706175 5th Dec 2024 7:41pm
dave the builder
Please let me know how you get on.
Post #710142 25th Jan 2025 3:02pm
sgorianin@gmail.com
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
As I replied in your other post you can't just swith for the 1 camera newer setup.
Maximum you can do to get them both out, drill holes in the bumper, extend the leads and glue them in with demeaning strong.
But at the end of the day, believe me, you will bring everything back.
Use your parktronic system to avoid hit the wall.
Post #711649 12th Feb 2025 3:02pm
Memoliito
United Kingdom 2016 Range Rover Autobiography 4.4 V8 Fuji White
My one is 65 plate and has 1 front camera
Post #713528 7th Mar 2025 10:00pm
sgorianin@gmail.com
65th plate is a different build up which has different multimedia and different hardware and software. They are not interchangeable you can't even simply replace the modules as some of the can buses works differently and they have different packs sent throughout the network.
To get it work as it on your 65th plate you need to change entire system with multimedia and coded it for the different setup.
1st thing it costs A LOT
2nd doubt that someone even jump.on to it to get married with the car and coded it works as it should
3rd it simply doesn't worth of it
Post #713529 7th Mar 2025 10:33pm
