Home > Wheels & Tyres > L405 bigger tires?
royael123
United States 2017 Range Rover HSE TDV6 Fuji White
L405 bigger tires?
Upsizing tires, anyone run 8 lug 22x12?.....
Post #705727 29th Nov 2024 6:32pm
Vogue
The biggest you can go combined width and height without rubbing or modifications is 285/50/20 or equivalent diameter and width on standard wheels. And that allows for access mode, standard ride height and off road height.
If you go narrower then yes larger diameter can be fitted. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #705729 29th Nov 2024 7:45pm
royael123
Got it, thanks
Post #705730 29th Nov 2024 7:50pm
