Home > Off Topic > Vinyl to digital conversion |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1475 |
I gave up, it’s too time-consuming when you can stream most tracks nowadays . The snag is, to add meta data, you need to record each song as a file. Check this out:
28th Nov 2024 4:11am |
MikeO Member Since: 02 Jan 2018 Location: The Cotswolds Posts: 518 |
You could capture each side using Audacity and use Silence Finder to split into separate track files.
28th Nov 2024 10:12am |
Kot Member Since: 10 Mar 2021 Location: broadland Posts: 1216 |
Buy the CD on eBay for a few pounds, add to apple Music app with a portable usb dvd/cd player connected to laptop, it will have the best quality compared to vinyl and it will be available on all your devices. Cast from any device to any compatible TV/music system etc use of Siri etc 2018 SE SDV8 4.4 Byron Blue |
28th Nov 2024 10:43am |
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 564 |
Hi,
28th Nov 2024 12:25pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 584 |
Many thanks all a lot of useful information.
28th Nov 2024 7:33pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 116 |
I thought Audacity could add metadata - I am sure it can for WAV files anyway.
29th Nov 2024 6:15pm |
Hi Chris,
29th Nov 2024 11:29pm |
Agree with Gremlin that Audacity can add meta data but as he says its a manual process.
30th Nov 2024 2:18am |
Yup. If you digitise vinyl, you get a single track with some silences in it. A CD is multiple tracks, and a Table Of Contents (TOC). The TOC is basically unique for each CD (what are the changes of two different CD's having tracks of exactly the same lengths?), so you can use the TOC as a lookup as to what the CD is. https://gnudb.org/ or Gracenote are examples of these indexes. Chris. L405 - 4.4SDV8 Vogue P38 - 4.6V8 HSE Land Rover series IIA V8 |
30th Nov 2024 9:17pm |
