![]() | Home > Technical (L405) > Auxiliary heater fault codes |
Fifth Horseman Member Since: 04 Jul 2016 Location: Lanarkshire Posts: 230 ![]() ![]() ![]() |
Symptoms are typical of the heater pump being faulty, others have had this fault as well. Good luck as access is not the easiest.
Pablo398 Member Since: 31 Dec 2023 Location: Wales Posts: 29 ![]() ![]() ![]() |
Thanks, thought that might have been the one. Came up as climate sensor when I googled number so wasn’t sure. Not worried about mechanical stuff but not great at electrical so thanks again for the help.👍 |
Hi, does anyone know if the last 2 digits of the number an important?
I wouldn't bother with a used sensor, especially at the price they are on eBay, you would likely have as much or more luck with the chinese sensors there.
Great thanks for the part number.👍 |
