Home > In Car Electronics (L405) > Speaker noise after heavy rain
Benner91
United Kingdom 2007 Range Rover SE TDV8 Java Black
2013 tdv8 autobiography
Hi after the rain last weekend I opened my rear door behind the passenger seat and water came out
Today my speakers are giving out a terrible loud static noise
Is there a fuse I can remove to stop the noise I don’t care if I have no audio for a week until I can get the problem fixed
Thanks
Post #705420 25th Nov 2024 6:09pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I would be very concerned the sunroof drains have blocked/failed and filled up the rear footwell, have you checked the sunroof drain points, assuming you have a sliding roof. I think there is plenty to fry under there.
Post #705426 25th Nov 2024 8:17pm
Benner91
Hi thanks for responding we’re are the drains located thanks
Post #705427 25th Nov 2024 8:19pm
DrF
Open the sliding roof, look about 4inches towards back of the gully you will see a small hole one both sides.
Check out the link on Range Rovers Forum.
https://www.rangerovers.net/threads/sunroo...7/#replies
Post #705428 25th Nov 2024 8:22pm
DrF
If it is that then you need to sort asap as damage will be massive if it continues.
Good luck and I hope its not.
Go to page 6 and it shows exact location, I have been looking at this link for a repair, seems less hassle.
&t=362s
Post #705429 25th Nov 2024 8:23pm
Benner91
Thanks I will do this first thing tomorrow
Post #705431 25th Nov 2024 8:25pm
Benner91
Hi does anyone know and have photos of were the sun roof drain pipes exit the car I can’t find them anywhere
Thanks
Post #705571 27th Nov 2024 8:01pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
It's under the rear wheels cowl, you can see in the video at min 5:24
Post #705579 27th Nov 2024 9:46pm
Benner91
Thanks ☺️
Post #705580 27th Nov 2024 9:47pm
