Home > Technical (L322) > Motorway Mode - suspension |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
ranges up to 2005 go into motorway mode at 65mph'ish, yours goes to motorway mode at 100mph... |
29th Jun 2011 4:18pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
my one goes into motorway mode at 70mph i think 100mph is to high as legally you would be breaking the law.. V8 facelift Range Rover Autobiography 22" wheels.
29th Jun 2011 4:58pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6703 |
Only if you get caught! Got - 2017 SDV8 Autobiography in Loire Blue Had- 2008 TDV8 Vogue SE in Java black Had - 2007 S/C in Stornoway Grey |
29th Jun 2011 7:16pm |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 |
100mph (or 160kph), correct, or at least that's what the manual says. Land Rover customer assistance did confirm to me that the 'true' speed is 100kph (62.14mph) for 30secs - it should return to normal when below 80kph (49.71mph) for 60 secs.
29th Jun 2011 8:27pm |
Mikeyjd Member Since: 14 Jun 2011 Location: Wrexham Posts: 543 |
If you are measuring the height when the car is parked, it will not be at the motorway height. No longer FF owner but still interested. Present car Jaguar XE ............................................ Previous car Td6 SE ................................ Previous LR- Disco 300TDi Auto |
29th Jun 2011 8:55pm |
I am taking several measurements, directly at the side of the motorway, just off the motorway (park and ride) and stationary. Access mode measures at 118cm.
29th Jun 2011 9:39pm |
ric355 Member Since: 02 May 2011 Location: Surrey, UK Posts: 302 |
You haven't stated what year of vehicle you have. I was poking around in all the various versions of the manuals, and couldn't find one that doesn't have a motorway indicator except for a 2007+ car which has no mention of a motorway level at all.
29th Jun 2011 10:04pm |
Huh? My RR was originally sold in Rome. It has the motorway height indicator. I bought a US manual via ebay (can't read much Italian) it shows the motorway height indicator. And, while I will admit that it's one of the details I have not spent a great deal of time observing, I am relatively certain that every L322 I've ever been in had a motorway height indicator - both here and in the US. (And I have been in quite a number now. Don't actually think I've ever been in a UK spec L322 tho, come to think of it) Where is this info from? A much better way to measure (oem spec actually) is at the wheel arches, BTW. It's easiest either measuring ground to wheel arch or upper wheel edge to arch (on level ground!). RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
29th Jun 2011 10:12pm |
Actually, it would be if you parked before driving 1 minute at under 45mph. RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
29th Jun 2011 10:18pm |
I didn't think this was the case either, which is why I went poking about in various manuals. In a 2007 manual there is no motorway height indicator, but there is no mention of motorway height at all. Any manual I found that mentioned motorway height had a height indicator on the console. I didn't read *all* of them though! |
29th Jun 2011 10:21pm |
30th Jun 2011 7:33am |
Does the manual you downloaded actually make any reference to motorway height? I had a feeling it just doesn't exist in the later models based on what I saw last night. |
30th Jun 2011 12:31pm |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
That looks just like my UK spec TD6 suspension panel and I have never noticed any lights to indicate "motorway mode" - I have to admit that I assumed it may lower by 1" automatically above 60mph, but didn't need to tell you about it ! |
30th Jun 2011 2:25pm |
davidp's diagram is for the td6/4.4petrol up to 2005 model...not sure whether the facelifts had the same control though.. |
30th Jun 2011 3:14pm |
