![]() | Home > For Sale & Wanted > [wanted] - Luggage / dog net for L322 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3217 ![]() ![]() ![]() |
Ive got a couple available in different colours (mainly light - sand/tan). all working and in good condition.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16334 ![]() ![]() ![]() |
Also, they don’t fit all late 322’s… Worth making sure its an option you can fit first sir… |
RobsterPC Member Since: 14 Oct 2024 Location: Kent Posts: 124 ![]() ![]() |
Thanks gents. What footings are needed?
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7897 ![]() ![]() ![]() |
But you might not have the bottom fittings for the cartridge to connect to, near the rear side windows behind the rear seat. My 2011 didn’t. My 2003 TD6 did.
Previous cars : 2003 Range Rover Vogue TD6 1999 Discovery Td5 ES 1995 BMW M5 3.8 6 speed 1992 Range Rover 3.9 Efi Vogue 1992 BMW M5 3.8 1988 BMW 735i SE 1989 Ford Sierra XR4x4 2.9i 1981 Ford Fiesta Supersport |
Ramblin Man Member Since: 05 Apr 2022 Location: Southsea Posts: 289 ![]() ![]() ![]() |
FYI: I found it hard to get the parts required for the cassette footing for my 2012 : LR made some of the brackets obsolete some while ago.
The Guardsman is what I've got, it's good but as a solid barrier that also needs tying down, it's not easy to take it out and quickly put it back in as a retractable one, hence my question.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2588 ![]() ![]() ![]() |
As a side note, I also have a couple of retractables kicking about and the reason is that MY dogs, so not all, can squeeze through the gap at the side, well behaved dogs are OK |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1261 ![]() ![]() ![]() |
We bought a Guardsman dog Cage years ago for our P38 and had it customised to fit our '52' plate L322. It is now in the back of our '05' 4.2 Supercharged L322. Absolutely brilliant (but heavy!) dog cages! Ours has the double rear doors plus drop down plywood ramps, split divider (not used) and the forward facing escape doors. It was expensive when we bought it but it must be well over 20 years old now and has had a couple of coats of Galvafroid to spruce it up a bit for the new (to us) S/C fatty!! |
Where can I get these "well behaved dogs" that you speak of? Maybe that's the issue! |
Robster, I think Amazon is a good starting point, made of plastic if memory serves me well |
There are a few mounts on the bay of e, but depends what colour you need. Think I searched for L322 dog guard mounts and then fixings.
