Home > Technical (L322) > L322 4.4 TDV8
Dijit
Scotland 2007 Range Rover Vogue TDV8 Java Black
L322 4.4 TDV8
Does anyone know of any way to test the fuel injectors on an L322 4.4 TDV8 without removing them and having them bench tested. Can they be tested in situ?
Thanks. Rehab is for quitters!!!
RR 2007 3.6 TDV8 Java Black *
RR 2007 3.6 TDV8 Zermatt silver *
RR 2000 P38 4.6 Met red *
Mercedes 300TE 4-Matic *
Jaguar 420 (1969) *
Nissan 300Z
Citroen XM 2.5TD X 6
Bentley Continental R
Hydrocon Highlander
Hydrocon Hamilton
Hydrocon Huntly
Am told the ones with a * are to be offered for sale! 😳
Departed
LR 1992 110 2.5TD
RR 2000 Holland & Holland 4.6 LPG
RR 4.2 Supercharged with LPG, Vogue SE 2007 Buckingham Blue
RR 2002 4.4 V8 Zambesi Silver
Post #704864 19th Nov 2024 10:58pm
GraemeS
Not other than relying on the pcm's ongoing checking that they are performing within spec and if out of spec then DTCs will be logged. The pcm checks that the crankshaft accelerates within an acceptable range when an injector is fired and tries to adjust the firing to get the acceleration within spec whilst keeping the adjustment factor within the acceptable range.
Post #704869 20th Nov 2024 4:43am
