Home > General (L405) > MPG drop - L405 4.4 SDV8 |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 148 |
Winter diesel would be my prime suspect. 2012 Vogue TDV8 in Aintree green |
18th Nov 2024 12:38pm |
bigdave Site Sponsor Member Since: 27 Jun 2011 Location: Cornwall Posts: 205 |
Check to see if any of your wheels are warm - might be a slightly binding calliper.
18th Nov 2024 12:47pm |
Iceboy74 Member Since: 20 Sep 2023 Location: Berkshire Posts: 20 |
Tyre pressures are good but I will check to see if the callipers are binding...good shout.
18th Nov 2024 1:49pm |
Jeffers7250 Member Since: 20 Sep 2024 Location: Oxford Posts: 8 |
How scientific is your recording… are you going by the dash or a physical refill and number crunch?
18th Nov 2024 6:46pm |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 478 |
its more likely the drop off in efficiency with cold engines, diesel engines take an age to thoroughly warm up. Truck engines shouldn't ideally ever get cold. First time FFRR owner |
18th Nov 2024 8:09pm |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 382 |
I'm surprised with you getting 36mpg at 80mph from the SDV8.
18th Nov 2024 8:20pm |
Dtech Member Since: 29 Nov 2014 Location: Yorkshire Dales Posts: 51 |
I think the FBH must add quit a bit to total fuel consumption at this time of year |
18th Nov 2024 8:46pm |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 |
Dpf regening more than it should be? Cheers
18th Nov 2024 9:00pm |
Hello All,
23rd Nov 2024 11:09am |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 351 |
I'd go with Dtech, more than likely the FBH Current
23rd Nov 2024 11:45am |
How would I know this? There have been occasions where I've been sitting on the motorway cruising at say 75-80 leptons, and look the continuous mpg and it's hovering around 25=26mpg, when I know it should be reading 35+ on flat sections. Any thoughts on how I know if the dpf is regening too often? It shouldn't really be the case, that car is 95% driven on long motorway journeys. |
24th Nov 2024 7:09am |
ABAB Member Since: 02 Feb 2017 Location: GB Posts: 283 |
Try this. Not a light read though!
24th Nov 2024 8:22am |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3235 |
DPF regeneration has an insignificant effect on mpg. Typicaly it takes 10 miles at motorway speed at a 10mpg loss. The FBH will hit mpg more as will cold air temps generaly for low load cruising. 2012 TDV8 Vogue (L322) |
24th Nov 2024 11:32am |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
I did 2 return trips from Glasgow to Aberdeen last week, used the FBH each time and returned just under 37MPG at a steady 65MPH. Got - 2017 SDV8 Autobiography in Loire Blue
24th Nov 2024 3:59pm |
