![]() | Home > Technical (L322) > Desperately needing help.. |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2561 ![]() ![]() ![]() |
From the owners manual..
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 216 ![]() ![]() ![]() |
I had this back in May this year going down to Strata Florida in Wales. Changed the battery in the key, still the same After numerous random smart key not present messages it was fine. Worked out it only did it when my tomtom sat nav was plugged in and switched on and/or phone was on charge. It’s never done it since. Could be something blocking the signal. |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 154 ![]() ![]() ![]() |
Not sure if relevant but the key does not operate the locks now so pushing the lock/unlock buttons does nothing. Will try the steps in the provided manual again today with fingers and toes crossed. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
Ansi Member Since: 07 Nov 2014 Location: Muenchwilen TG Posts: 146 ![]() ![]() ![]() |
Wrong battery side in the key? New battery not really new? Make sure there are no fingerprints on either side of the battery. Clean the battery before inserting and hold it with a napkin or tissue only.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
..and check the thin plastic protection cover is removed . ... - .- -.
Scouse Exile Member Since: 09 Dec 2022 Location: East Midlands Posts: 394 ![]() ![]() ![]() |
Hi,
RRV8SC Member Since: 02 Oct 2021 Location: SW London Posts: 179 ![]() ![]() ![]() |
Is it a Duracell battery with child proof coating?
The battery I removed was also a Duracell and no more than 6 months old. The new battery has the plastic film removed and was cleaned before inserting. I have just received another pack of Duracell battery’s from Amazon so will try one of these.
I took the key apart and put it back together again as well as leaving the car on charge. It now starts so not sure what I did or didn’t do.
Good news. |
I had some other brand battery’s but read on here advice to only use Duracells!!
