Home > Technical (L405) > Parking brake actuator replaced under LR extended warranty ? |
ReggieMac Member Since: 10 Sep 2023 Location: Wolverhampton Posts: 180 |
Cant say whether warranty should cover or not but even if they dont that price quoted is obscene. Just a quick Google shows the parts are relatively cheap
15th Nov 2024 3:55pm |
lambo911 Member Since: 13 Jan 2022 Location: St Albans Posts: 89 |
I will do it myself if they won't cover it.
15th Nov 2024 4:02pm |
As far as the warranty is concerned I am pretty sure that they will always say it was the water ingress first that subsequently caused the cracking but common sense would suggest that it is clearly the other way around. _______________________________________________
15th Nov 2024 4:07pm |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1378 |
Main dealer strapped mine up for a year with cables ties and didn't tell me so it was out of warranty before i realised there was a problem and they failed, then said it was water ingress and duly emptied my wallet. I think you are on a hiding to nothing so get the best price you can. |
15th Nov 2024 5:01pm |
ChrisJC Member Since: 14 Sep 2023 Location: Northants Posts: 110 |
I got mine from here:
15th Nov 2024 6:43pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
You can get aftermarket replacement actuators for less than £20 on eBay. Part no. LR036573 They are the same part as used on some BMW models part no. 34216794618.
15th Nov 2024 8:24pm |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 860 |
As Kev says above, I’ve also replaced these on the driveway using aftermarket parts, it’s not a particularly difficult task. Jonathan
15th Nov 2024 8:31pm |
Just make sure to check before buying your parts because some have the square electrical connector and some a rounded one....
15th Nov 2024 8:38pm |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1410 |
Yes, don’t get it wrong:
15th Nov 2024 9:42pm |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 311 |
What a good business, invest 60 GBP, one hour and write a bill from 1.100 GBP, like Bitcoin trading )
16th Nov 2024 9:55am |
Has anyone actually been successful in getting the warranty to cover it ? If you can show the casing failed first then they can't argue it was corrosion ? 2016 AB SDV8 Barolo black |
18th Nov 2024 5:26pm |
