Home > Technical (L405) > Infotainment screen gone blank. No climate,radio,rev cam etc
james76
United Kingdom 2013 Range Rover Autobiography SDV8 Luxor
Hi,
Had my 2014 L405 RR for 6 yrs with no problems but 2 months ago my infotainment screen went blank. It came back briefly for a few days after the car was left unused for a week but has since permanently failed.
This has stopped the heating/ac, the radio, satnav, the reverse camera, etc.
I bought and fitted an aftermarket replacement/upgrade, but this too is also just blank.
I have checked and changed a number of fuses that I think are related to the audio/infotainment unit with no joy. (Although it’s v hard to know which fuses relate to the screen)
There is some power reaching the console as the hazard warning light button still works.
I’m currently left thinking it’s a loose wire or a faulty connector but is there any way to find it?
As winter is approaching I really need to be able to heat the car.
Any ideas?
Post #703805 5th Nov 2024 1:42pm
check the battery... ... - .- -.
Post #703812 5th Nov 2024 2:58pm
james76
Edit: Both car batteries are less than 12 months old and have been checked. No low battery warnings either.
Post #703815 5th Nov 2024 3:21pm
ok thats good..
there have been reports of the earth cable breaking/corroding in the near side front arch.....worth a check...
theres also a workshop manual dowload link in our wiki... ... - .- -.
Post #703817 5th Nov 2024 3:23pm
Gremlin500
Hi James, do you have an OBD scanner?
Worth scanning for DTC’s before you go down too many rabbit holes, but Stan is right, and on a MY2014 the earths are a prime suspect. Read: https://www.fullfatrr.com/forum/topic63901.html “If it ain’t broke, don’t fix it” -where’s the fun in that?
Post #703825 5th Nov 2024 3:59pm
james76
Sorry for slow reply. I’m about to check the front passenger side earth point in the wheel arch. I Couldn’t find any Wiki instruction guides (I’m new to this website) or you tube videos.
Is the earth point behind the casing at the front or rear of the wheel arch? Thanks
Post #704030 8th Nov 2024 10:34am
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
I had an issue with my earth points, link below, might be helpful
https://www.fullfatrr.com/forum/topic65812.html
Post #704045 8th Nov 2024 11:56am
