Home > Technical (L322) > Rear sunroof drain exit location |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 832 |
I used some of the cable from a net curtain, flexible and strong to poke all the old debris down the drains
3rd Nov 2024 11:38am |
RG2024 Member Since: 08 Oct 2024 Location: Warwickshire Posts: 32 |
Aha thanks for copying that diagram. I’ve removed several grommets & fixings down the pillar & stuck a small camera into the holes on both sides and had worked out the drain must go right down by the door shut because there’s a distinct lack of pipe visible through those holes on either side!
3rd Nov 2024 12:59pm |
Where the arrow is pointing in the diagram is typically where it rots and rust/corrosion takes hold, and the longer the water is blocked in the drain, eventually the sill will need replacing ( and the jacking point ) , and MOT fail due to the rear passenger belt anchor point being compromised, really poor design on the part of Land Rover / BMW back in 2001
3rd Nov 2024 1:23pm |
Yes so it looks like it’s had the outer arch skin replaced, but the sill will need a repair too and I’ve seen those repair panels on his website so I’ll have a look at them when I’ve solved the drain location & water ingress issues!
3rd Nov 2024 5:17pm |
Hoping I’ll be able to drop the reservoir enough without disconnecting the air line, to get a better look at the recess & maybe get something in to clear the drain if that’s what I saw '95 VW Corrado VR6
3rd Nov 2024 5:57pm |
NobbyC Member Since: 29 Dec 2015 Location: Princes Risborough Posts: 122 |
Remove the rear arch liner and you should be able to see the drain pipe sticking out of the body. See https://www.fullfatrr.com/forum/topic50758.html |
3rd Nov 2024 7:32pm |
I’ve done that on both sides. It’s clear to see on the passenger side but there’s definitely nothing there on the driver side. I’ve poked about to make sure it’s not just been undersealed over or anything & it’s all solid metal around that area.
3rd Nov 2024 7:41pm |
Found it! It’s in the wheel arch, and it was behind the weld repair. So whoever did the repair seemed to think it was fine for the drain to just be sitting inside the wheel arch
10th Nov 2024 6:18pm |
