Home > Maintenance & Mods (L322) > Coolant Leak
EvolutionUK
Coolant Leak
Could anyone advise on a coolant leak which is roughly in line with the near side front wheel? The car has been sat for a few weeks and has randomly started a small leak when cold. I noticed it was a bit low the other day so I topped it up cold with the bleed plug in the expansion tank off, now it seems to be more obvious on my driveway!
Are there any common issues to check in this area?
Many thanks
Matt
Post #703565 1st Nov 2024 2:08pm
jamiej
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
I had a recent coolant leak and the only way to find it was to mildly pressurise the system with a kit from fleabay and then look carefully.
Once you know where the leak is, the legends from the forum will advise how to fix.
Good luck
Post #703572 1st Nov 2024 4:19pm
