![]() | Home > Maintenance & Mods (L322) > 8 speed ZF - Power Flush vs. Sump off and filter replacement |
RangeAnxiety Member Since: 17 Oct 2024 Location: Worcestershire Posts: 16 ![]() ![]() ![]() |
I’m collecting my (new to me) L322 4.4 TDV8 in a few days time. It’s my first Range Rover, but far from my first older car.
Alex1976 Member Since: 22 Mar 2023 Location: Bucks Posts: 158 ![]() ![]() ![]() |
At 60k miles I went through the process of dropping the oil and refilling 3 times over the course of two weeks, driving it circa a hundred miles between each oil drop. On the final drop I also then changed the filter. The oil went from black to almost bright green as the new oil was over the course of the process. I would estimate I have changed 90% or more of the oil and given it a good flush through.
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7880 ![]() ![]() ![]() |
Get in touch with Bodsy. He does megaflush. I had that done in March, with both diff oils and transfer box oil. £500 odd. Can’t go wrong.
Whatever you decide to do I’d recommend it involves genuine ZF oil. IMO ‘flushing’ is unnecessary and simply replacing a good proportion of the oil with genuine ZF fluid and replacing the pan is enough on these boxes which are very reliable and will usually outlast the rest of the car. 2012 TDV8 Vogue (L322) |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
I’ve had two mega flushes, one at 82k when I bought her 5 yrs ago & then had Bodsy come down to the sticks this year & had another mega flush done at 105k. Overkill? Probably, but for piece of mind 99% of the oil is replaced via a mega flush.
I don't trust 'gut feelings' when it comes to car maintenance but whatever makes you happy |
maz Member Since: 28 Sep 2024 Location: Perthshire Posts: 6 ![]() ![]() ![]() |
Did my filter replacement a few weeks ago, easy job and not worth paying £800 for. I dont really see the point if you arent replacing the filter. Also there are magnets on the filter base and will most likely have a thin film of metalic sludge on them so you are replacing those magnets as well and helping them perform better in the long run. The flush is just an oil change. 2011 4.4 TDV8 Vogue Grey/Ivory |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4327 ![]() ![]() ![]() |
Just use Bodsy and be safe in the knowledge that he knows what he's doing and has done literally hundreds of them.
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 818 ![]() ![]() |
Anxiety…
Apache Member Since: 07 Sep 2024 Location: Yorkshire Dales Posts: 4 ![]() ![]() ![]() |
https://www.advancedfactors.co.uk/lr065238...8462-p.asp
