Home > For Sale & Wanted > [Wanted] Battery for L322
Tiprat
I thought I’d ask here before buying one on line from the likes of Tanya, I’m after a new battery for the RR, the one that’s on it is a Bosch S5 015.
If anyone’s local il collect ect
Regards
Tiprat Borrowed Grey 2002 3d 204k for a year
Now own a 2007 Java black Vogue SE 3.6TDV8 160k
Post #702842 22nd Oct 2024 2:06pm
J2B
England 2010 Range Rover Vogue TDV8 Ipanema Sand
One here on page 2 of the for sale/wanted section, don't know if they still have it but maybe worth a pm.
ditchvisitor wrote:
Brand new, from Tanya, Bosch S5 015, never fitted and 2 months old. Biggest battery you can fit in an L322.
£90 collected
https://www.tayna.co.uk/car-batteries/bosch/s5015/
Post #702931 23rd Oct 2024 7:45pm
Tiprat
I did send a PM but got no response, so I'm still looking, il give it a bit longer then buy one. Borrowed Grey 2002 3d 204k for a year
Post #703095 26th Oct 2024 8:28am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
An 015 size is on the small size gor an L322.
Best is an 020 - but doesn't fit all.
Or slightly shorter is the recommended size which is the 019 Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #703096 26th Oct 2024 9:10am
Tiprat
Thank you Pawl, I hadn't spotted that just thought it was a 019 or 020. At present the one in the RR is a 020. Borrowed Grey 2002 3d 204k for a year
Post #703098 26th Oct 2024 9:39am
Nige67
Can recommend the Bosh. Tight fit in the battery compartment but it will sit snugly.
Replaced an 019 AGM Halfords, 2 years old, would shut of FBH and Audio systems with low power warning after 2 mins.
Bosh yet to have that issue.
Car driven long journeys up to Scotland at least once a month so charging not the issue, also had the AGM on a NOCO genius 5 over night, didn’t solve the low power issue.
Just adding some user feedback as it all helps the informed decision making.
Post #703442 30th Oct 2024 6:13pm
