Home > General (L405) > Oil change
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
Oil change
What’s the going rate for an oil change?
4.4 sd V8
Chefski 2014 vogue se
Post #702798 21st Oct 2024 7:34pm
supershuttle
I paid 20 quid to a local garage and I provided the correct oil, they didn't suck the oil out but drained it via the sump plug. I don't actually know if this is any better than using a vacuum pump. Same engine SDV8 Diesel. Geoff
Post #702814 21st Oct 2024 9:53pm
Mine was around 160-200
Oil was 90, sump plug a fiver then labour. I had other work done so not sure exactly how much was the service, but 65/hour
Post #702816 22nd Oct 2024 8:08am
chefkenmore
I’ve just paid £175, plus £30 for oil disposal, £70 per hour.
About correct then? 2014 vogue se
Post #702825 22nd Oct 2024 9:30am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
Smith & Allen oil [full C1F spec] is £39.10 for 9.2l and a decent quality filter is about £10 - so just less than £50 if you do it yourself. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #702845 22nd Oct 2024 2:37pm
