Home > Maintenance & Mods (L322) > Has anyone replaced the ABS/speed sensor ? |
Why does it need replaced? have you tried cleaning it up?
28th Jun 2011 8:17am |
EDWARD757 Member Since: 10 May 2007 Location: SOUTH COAST Posts: 181 |
Hi,
28th Jun 2011 10:44am |
swast4 Member Since: 07 Jan 2011 Location: Wirral Posts: 69 |
I've managed to get the retaining bolt out ok but can't get the sensor out it is stuck solid and have tried with pliers but no joy.
30th Jun 2011 6:13am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1320 |
It can be drilled out fine. You find as you get the drill into it, it may free up and spin with the drill. Plus if you have your replacement you know how deep you can go
28th Aug 2011 10:21pm |
Yeh, I managed to drill it out fine using the oild one as a template and put some masking tape on the drill bit to make sure I didn't drill too far.
30th Aug 2011 4:38pm |
pretlove Member Since: 10 Feb 2011 Location: Bas vegas Posts: 1865 |
maybe you now need to remove the fault code using a obd tool i had to when i let my brake wear indicator wear all the way down "RANGEISM WILL NOT BE TOLERATED"
30th Aug 2011 8:48pm |
check the cables running up from the abs sensor, up the damper and across to the inner wing ... they can pop out from the clips and be rubbed away by the tyre. V8 or else ... |
1st Sep 2011 8:15pm |
Thanks for the suggestion, I have checked the cables already and they are all fine into the inner wing.
11th Sep 2011 1:59pm |
Hi Guys,
25th Oct 2011 11:30pm |
Interesting. It must have been out by a fair bit was it?
26th Oct 2011 8:55am |
petewild Member Since: 14 Mar 2013 Location: Croydon, Surrey Posts: 45 |
17th Mar 2014 10:34pm |
