Home > Technical (L322) > L322 4.4TDV8 - wont start, multiple clicking from dash
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Getting into the FF on Monday, on pressing the start button it doesn't start, just makes lots of rapid clicks from the dash. A couple of random messages (like the low range symbol) flash up, then it dies.
Tried locking and unlocking and repeating - no change.
Never had this issue before.
Occasionally it clicks once on pushing the start button, but it always starts the next time. I'm assuming that's a different issue, as a don't see why a failing starter relay would throw up loads of dodgy messages.
Off to check the battery voltage, then the block to earth resistance.
Any suggestions would be welcomed!
Post #701904 10th Oct 2024 12:00pm
Weegie
I would suspect the battery. John
GAP iiD BT-Sold
Post #701905 10th Oct 2024 12:20pm
NDT
so would I - voltage is only about 8v.
On charge now.
Post #701916 10th Oct 2024 1:58pm
BAZ8046
If it has got to 8v it's time for a new one! 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #701921 10th Oct 2024 4:10pm
