![]() | Home > Technical (L405) > 2018 L405 - Motorway Vibration |
MarianaWestminster Member Since: 14 Jun 2018 Location: UK Posts: 719 ![]() ![]() |
Road force balancing differs to traditional spin balancing in that the machine used has a big roller which is pressed against the spinning wheel and tyre assembly thus emulating forces applied to the tyre when travelling down a road.
Andy S Member Since: 16 Jun 2013 Location: Sevenoaks Posts: 1053 ![]() ![]() ![]() |
Update.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1401 ![]() ![]() ![]() |
If anything the 5.0SC is smoother than the SDV8 so should not vibrate, mine hasn't done so. Two buckled wheels (even allowing for the greater vulnerability of the 22s) suggests the car has been thumped about. An impact that is hard enough to buckle a wheel would be apt to damage a tyre too. If you have noise reducing foam in the tyres this can come loose and cause imbalance, with adverse effects on running smoothness.
Thanks, that’s useful feedback. The local dealer checked the suspension and said all was fine - and I trust them to be straight with me.
Another update.
