Home > Technical (L322) > 4.4 TDV8 Vibration/Rumble - RPM related
Page 4 of 4 <1234
kevinp
I think he just strapped it out of the way to test it.
Post #626964 25th Mar 2022 11:46am
hotpotatojr
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
Yep just zip tied out of the way to test it. New hella fan, bearings and belts all on their way so will update the thread when it's done.
Notice the hammering marks on the fan nut, could have been physically damaged when they changed the water pump in its previous ownership (found the receipt for it).
Post #627005 26th Mar 2022 1:22am
Suchej
Czech Republic 2011 Range Rover Vogue TDV8 Barolo Black
Hello there! I’m having the exact same issue as you were describing and trying to resolve in this thread. Did it ever have any conclusion? I haven’t tried disconnecting the viscous fan yet, but I indeed replaced it and it still persists. Thanks for any notes!
D.
Post #671439 17th Aug 2023 11:13pm
steph_boldt
Germany 2007 Range Rover Vogue TDV8 Stornoway Grey
So did this solve the issue? I have the same! Cheers!
Post #693046 21st May 2024 5:13am
Suchej
Just so you know, in my case it seems that the viscous fan is functioning normally. The diag shows its engagement and disconnection without a problem. Still not sure though. I guess the only way to say is to physically disconnect the fan and do the test drive. Still finding some time to do that.
Post #701340 3rd Oct 2024 6:55am
Page 4 of 4 <1234
