Home > Technical (L405) > 2013 SDV8 Low speed juddering after flood wading |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1350 |
Did you re-calibrate the transfer box ? It needs to re-learn the clutch position when new fluid goes in.
27th Sep 2024 6:01pm |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2469 |
If a locking rear diff is fitted then did you use the correct oil? |
27th Sep 2024 8:51pm |
Neil183 Member Since: 21 Dec 2016 Location: Rickmansworth Posts: 42 |
I used what the dealer sold me. ie DTF-1 for the transfer box 1.5 litres and .82 litres of SAF-X0 TYK500010 in the diff with new washers and plugs.
27th Sep 2024 9:43pm |
That diff oil is for an open diff so if you don't know if an e-diff is fitted then you should determine if your vehicle does or does not have an e-diff. This can be done either by inspecting the diff itself or by selecting rock-crawl, transmission in D and with the steering wheel straight ahead which should show either red(locked) or green(open) for the rear diff on the 4x4 display. |
27th Sep 2024 11:08pm |
Hi
28th Sep 2024 6:14pm |
How did the old transfer case oil look? If particularly dirty then a double flush and calibrate is the usual fix, with the wading and juddering perhaps coincidental. Recalibration isn't required with a regular oil change but if it hasn't been changed for a long time or the wrong oil was used previously then calibration will be required. |
28th Sep 2024 8:34pm |
The oil wasn't bad, it was last changed in Feb 2020 around 50k miles ago at an independent. |
28th Sep 2024 9:00pm |
I change mine every 40K kms so twice as frequently, but it does get a work-out in sloppy conditions every time there's rain. |
28th Sep 2024 10:52pm |
Managed to plug the OBD tester in today and read the code "P08A-54 clutch position not learnt" on the TCCM module.
30th Sep 2024 8:07pm |
It's a pity that as the control module knows that calibration is required that it doesn't just calibrate the next time the ignition is turned off, as the diagnostic tool simply commands the module to perform its calibration. Anyway, at least there is a code to follow-up. |
30th Sep 2024 8:31pm |
