Home > Technical (L405) > Should I be worried about my gearbox? |
peekay Member Since: 07 Nov 2011 Location: London Posts: 91 |
Just a bump on this in case anyone has any ideas |
25th Sep 2024 6:28pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
That's normal. From cold, the vehicle will hold onto the lower gears for longer. This is purposely to raise the temperature in a shorter amount of time. Kev
25th Sep 2024 9:16pm |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 748 |
If it didn’t do it before the oil change then it could be worth checking if the fluid level is correct, it’s easy to under fill it. Did it get the correct ZF fluid or a cheap alternative? |
26th Sep 2024 2:33am |
