![]() | Home > Maintenance & Mods (L322) > L322 4.4 V8 M62 Coolant Leak |
batfink Member Since: 20 Jun 2011 Location: Milton Keynes Posts: 205 ![]() ![]() |
Two things to check:
jamiej Member Since: 01 Dec 2023 Location: Surrey Posts: 59 ![]() ![]() ![]() |
Hi,
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1473 ![]() ![]() |
You can buy UV dye from the likes of amazon to put into the coolant ( I normally put 2 bottles in ).
Thank you. I will give that a go and let you know how I get on ... |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 988 ![]() ![]() |
Rear coolant cross over pipe, gasket can and does leak it can weep from the bolts that secure it also the connector on the rear very common I carry 1 in the car.
Thanks Dave (again). I'll pop in the UV and then have a look.
Some progress.
After some investigation, it appears that the problematic pipe is JHC000081, which seems to be a common issue.
So.
Nice 1 |
