Home > Wheels & Tyres > P400e downsizing to 20". Will Disco5 rims fit?
Walter Skinner
Bulgaria 2019 Range Rover Autobiography 2.0 PHEV Barolo Black
Hello everybody! Surely 21s look good, but I need a bigger sidewall for the place where I live. So I decided to go to the smallest possible for p400e wheels - 255.55.20 Scorpion Zero AS LR PNCS
Can someone please advice though... Back in the l322 td6 days I remember changing rims size required air suspension calibration. Will I have to do it in l405?
Another question relates to the pressure. Sticker on the door says 2.3 front & 2.5 rear for 255.55.20, but TMPS system in the car when set to light load expects (2.4) front and 2.8 rear, so something does not match well...
Would appreciate your responses!
Post #700338 18th Sep 2024 5:22pm
dingg1
Stop worrying, just drive the thing.
A slight change in wheel/tyre size isn't going to be an issue, and 4 psi change in tyre pressure is nothing to worry about đź‘Ť
Post #700340 18th Sep 2024 5:32pm
Walter Skinner
But it will scream the warnings all over the dash, thats my concern Smile
Thanks for response!
Post #700342 18th Sep 2024 5:39pm
Same rolling diameter so it will be ok. ... - .- -.
Post #700345 18th Sep 2024 5:51pm
Walter Skinner
Gotcha, thanks! And yup, forgot to mention I'm rolling on 275.45.21 now. Online calc says its within acceptable values.
Post #700350 18th Sep 2024 6:14pm
Walter Skinner
Ok, before I proceed, can someone confirm that Discovery 5 rims are safe to use? I don’t know much about load allowances, and p400e is a heavy beauty. For the lack of better options, I’m planning to get HY32-1007-RA, but there’s no “maximum load” specified…
Post #700493 20th Sep 2024 3:09pm
