![]() | Home > Maintenance & Mods (L405) > Filling / bleeding the coolant ... how to you manage it ? |
Tdtj Member Since: 29 Sep 2021 Location: Edinburgh Posts: 195 ![]() ![]() ![]() |
I was only reading about this a couple of hours ago. Seems to me you need to remove the rear wheel arch liner and disconnect pipes there. Of course I stand to be corrected 👍
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
MD's fill the system with a vacuum tool. Just had my coolant changed due to replacement gasket and there was very little fuss involved. Simple drain and suck fill. No rear pipes or wheel arches out. 405 AB exec seats Baltic and Cirrus
Mmmm as said stood to be corrected. Seems I misunderstood the rear was for drainage and flushing. Sorry.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1433 ![]() ![]() |
I’ll re-read the WSM and see how it goes. I cracked open one of the joins in the wheel arch and coolant came out … so the coolant is getting to there along one of the pipes. (I’m wondering whether there is a valve in the rear unit which is not letting the coolant flow through.
So had another stab at it this morning. ( I'll add pics a little later )
and then flushed the rear loop through with a hose + adapter till it ran freely.
Then re-connected one side back up, and with the hose still connected to the other, pushed more water into the rear loop and into the engine side to push out any air. Then lastly did a live re-connect to complete the joins. Fired it all back up, re-checked the bleed points and started to get heat coming out the rear vents ! woohoo. - - - - - - - - - In hindsight, I think you really need to drain the whole lot before filling. I suspect that the fill process fills from one side of the loop first as the levels rise, and as it does, it pushes the air out the return, but if you have a partially filled system, the existing coolant other parts of the return circuits block the air getting out, hence the air lock created. V8 or else ... |
Sounds like a pain in the buttocks. I had issues with mine a couple of weeks ago. It’s cold in the rear,but the heaters work great front and rear passenger compartment. So as the pooch is always in the back it’s better for him for now.
Just one of those things that you reach a point where you go sod it, I'll just have at it and accept I'm going to get wet. Much muttering was had thats for sure !
but dont quote me on that ! ![]() ![]() |
