Home > For Sale & Wanted > [For Sale] iPod Connector Lead
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
Found this in the back of a drawer - not sure if there’s still a market but thought I’d pop it on here to see if it’s of use to anyone. I believe it’s a genuine item and I used it with my 2011 L322.
£20 + postage
 Jonathan
2007 Defender 90 XS Hardtop
Post #700038 13th Sep 2024 9:55am
Brychangd
Hi Jonathan,
Can you share where in the car you plugged this in ?
Thanks!
Post #713249 3rd Mar 2025 6:03pm
JCW
There’s a socket inside the centre cubby box, 2010-12 models I believe Thumbs Up Jonathan
Post #713251 3rd Mar 2025 6:54pm
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
If you connect this to a cable jive 12v to 5v converter, then use a female to male lightning cable you can have your iPhone stream directly to the head unit.
Tracks are identified on the head unit and you can use the steering wheel controls to skip tracks, select tracks etc.
Sounds complicated, but it isn’t. The expensive bit is the 12v to 5v converter, which is used to drop the voltage to current iPhone charging voltage.
It also has the benefit of charging your phone and if you run the lightning cable through the centre console you can have a very short lead sticking out to connect the phone to.
https://www.amazon.co.uk/CableJive-dockStu...B003TJR2HS
Post #713255 3rd Mar 2025 8:17pm
