Home > Technical (L322) > Replace BCM?!?
Savageghost
United States 2015 Range Rover Autobiography 2.0 PHEV Fuji White
Replace BCM?!?
So my 2015 RR Evoque Autobiography was in a flood & I'm having issues. My fobs began disconnecting & my battery kept dying. I put a meter on it & discovered the alternator wasn't charging so I bought a new alternator & had it replaced & my keys reprogrammed. All was good for a day & once again alternator stopped charging & fobs disconnected. I bought a foxwell nt510elite scanner & the Jaguar program & ran a scan. I'm getting 3 permanent faults, one a medium CAN bus communication fault on immobilizer & a medium & high CAN permanent communication fault on the BCM. That leads me to believe the BCM is bad & not communicating properly with everything so I ordered a donor BCM(mfr same day, same BCM model) off a totalled vehicle & was hoping to take programming off existing & put on new & just swap out. Am I thinking about this right? Is this possible?
Post #700012 12th Sep 2024 11:00pm
How deep was it submerged...? Pete
Post #700016 13th Sep 2024 12:33am
Savageghost
Unfortunately don't know. Quite the predicament given the amount of electronics
Post #700018 13th Sep 2024 12:54am
Mikey
BCM isn't plug and play, it is VIN coded (and programmed)
You can't recode a used BCM without specialist equipment
Post #700023 13th Sep 2024 7:46am
