Home > Maintenance & Mods (L322) > Catalytic Coverters / Exhaust System for 2006 4.2 S/C |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1257 |
Our 2006 4.2 Supercharged has failed MOT on emissions. Its not too high and the O2 sensors have been replaced.
23rd Aug 2024 6:05pm |
All it shows on the test sheet is that the CO level is at 0.4% at Fast Idle speed and 0.813% at Second fast idle test. Limit is 0.2%
23rd Aug 2024 7:16pm |
RedFL Member Since: 13 Nov 2023 Location: Surrey Posts: 14 |
You need to put an OBD scanner on to get the data iirc it may say something like L or R bank catalyst is below efficiency. May be a P 1042 but I could be well wrong on that 🤔.
23rd Aug 2024 7:23pm |
Btw have you tried Keith Gott in Alton for the exhaust bits |
23rd Aug 2024 7:24pm |
Turns out that it wasnt the cat's that were the issue, but the O2 sensors.....
7th Sep 2024 5:57pm |
Glad it’s sorted was that for sensors in total or just the two down stream? Ironically mine is playing up now as well 😆 |
7th Sep 2024 6:01pm |
The sensors were around £250 each, not sure if they were the upstream or Downstream but it was throwing an intermittent fault with I think the Bank 2 sensor.
7th Sep 2024 6:07pm |
7th Sep 2024 6:08pm |
