Home > Maintenance & Mods (L322) > 64118391470 air quality sensor (JTF100130) where is it?
fatu
Czech Republic 2012 Range Rover Vogue TDV8 Sumatra Black
First post, apologies if making any mistake. Following many years, and learnt applied many things. Thanks to this community.
64118391470 air quality sensor (JTF100130) where is it? I have this problem l322 2008 3.6 tvd8 I have even gone to local shop and he could not find it, including moving the air filter box. I am getting this code with gap iid ao I know I need to change it and according to other message I found related to this, it is easy fix but I guess if you can find where it is. I failed searching all videos and images on the net, nothing there. Any help is appreciated. Thanks
Post #687563 8th Mar 2024 7:12pm
RRPhil
If this is the pollution sensor, then it's mounted on the fan cowl behind the radiator.
Phil
Post #687591 9th Mar 2024 1:16am
fatu
Thanks a lot. I looked throughly that area but could not see it. I guess I need to take the fan cowl out, is that right?
Post #687599 9th Mar 2024 9:33am
RRPhil
I don't think you have to remove anything to gain access?
Phil
Post #687606 9th Mar 2024 11:29am
fatu
You are truly a star. Thanks a million. Found it, changed it and all fixed.
Post #687622 9th Mar 2024 2:20pm
invisible999
United States 2005 Range Rover HSE 4.4 V8 Chawton White
Where did you get replacement part and how much did it cost?
Post #699645 6th Sep 2024 10:01pm
fatu
eBay Range Rover 2012 4.4 TDV8 - current
Range Rover 2008 3.6 TDV8 - previous
Range Rover 2004 3.0 TDV6 - previous
Post #699646 6th Sep 2024 10:04pm
fatu
https://www.ebay.com/itm/176330889308?mkci...media=COPY Range Rover 2012 4.4 TDV8 - current
Post #699647 6th Sep 2024 10:06pm
invisible999
Thanks. Shipping here is more expensive than the part itself.
Post #699650 6th Sep 2024 10:39pm
