![]() | Home > Technical (L322) > More L322 4.4 serpentine belt woes |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 217 ![]() ![]() ![]() |
Correct part number for the belt is LR022803 pretty sure it’s 6PK2515. I’d fit either genuine or Dayco. Were the pulleys and tensioner you had fitted genuine Land Rover? |
quint22cp Member Since: 17 Jul 2023 Location: West midlands Posts: 9 ![]() ![]() ![]() |
Yes, all pulleys and the tensioner were Land Rover parts, (well I paid top price but how do you know).
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2566 ![]() ![]() ![]() |
I can't envisage that a belt 5mm longer would flop about, so either a wrong size pulley is mounted, perhaps 2 swapped if that is possible, or the belt is incorrectly routed. Mine's genuine belt was very tight to fit, requiring the tensioner to be pulled back to its absolute maximum. |
I think that you have the wrong belt part number as the mentioned part number is for the L322 TDV8, not the L405/L494 SDV8 which is LR036090 and I can't see any supersession for the other part number, unless not for your L405. |
That makes sense GraemeS.
The one I fitted on mine was a Dayco 6PK2515. |
Fitted a Dayco 6PK2515, today and it runs like a clockwork mouse, very pleased.
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 119 ![]() ![]() ![]() |
https://imgur.com/MSZAjuz
Started from cold today and the noise is back FUUUURRRRRRCCCCCXXXXXX |
Eastsoutheast Member Since: 10 Jan 2023 Location: Wimblington Posts: 156 ![]() ![]() ![]() |
Everyone who knows me says I am the fussiest person they have ever known with cars as they have to be perfect. I too have belt squeal when cold which disappears after a minute or less. I asked a specialist for the cost to replace the pulleys and belt and after inspection was advised to live with it as nothing wrong or about to go pop. 2012 4.4 TDV8 Vogue Santorini black ivory leather |
Yes, I have since read a post on FFrr that a clicking noise from the fan area is "normal" for aging L322's, after initial cold start as it soon disappears. I can live with that, if it doesn't get worse, all fingers crossed. |
I'm on my 2nd replacement belt and tensioner in 3 years. The first one went bad after a few months and was very ( head turning) noisey for a long time. Had it replaced with a genuine tensioner and about 18 months ago and it's only now starting to chirp very slightly for a few seconds in the morning. The main load is the alternator in the morning and this also has the smallest pulley which has less friction and therefore will slip first. Any contamination of the belt with oil ( easy to do during servicing) or antifreeze will cause a loss in friction. Try some talcum powder but never use any belt conditioning sprays. 2012 TDV8 Vogue (L322) |
