Home > In Car Electronics (L405) > Blurry rear camera 2018 L405
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Had a very blurry rear camera on my car which I’ve now fixed. Thought I’d share the mistakes I made!
Firstly, I bought one from the same year breaker. This arrived and worked but was almost as blurred (obviously a common issue). Sent that back then ordered another from an evoque. This one looked the same but want compatible and it turned out there were four types:
The evoque one was type 2, typically mine was type 1. Ordered a third
This one worked a treat and was HD clear (£90 from eBay).
Was easy to fit, just pop off the strip across the back tailgate then swap the camera.
Worked a treat! Eventually Rolling with laughter My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #699577 5th Sep 2024 7:32pm
Maher2023
United Kingdom 2018 Range Rover Autobiography SDV8 Fuji White
Really useful. I’ll keep in mind when car is out of warranty. Bow down Cheers
Post #699644 6th Sep 2024 9:05pm
ivo_markov
Belgium 2016 Range Rover Autobiography SDV8 Indus Silver
Hi, is this the correct part number - LR052029?
found this video for evoque, is the procedure the same? -
this video also for l494 -
Many thanks!
Post #700029 13th Sep 2024 8:42am
hoppy_70
Yes, same process. Use a pry tool to pop off the strip then the camera housing just pulls down.
Saw some advice to drill two little holes in the housing at the bottom to let water drain out (sitting in it is what causes failure in the first place. I did that with mine, looks fine as the holes are underneath. My Previous RR's!
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
Post #700617 22nd Sep 2024 7:50am
