Home > Technical (L322) > What should be correct PSI for 255/50/R20 Nokian A/T tires?
invisible999
United States 2005 Range Rover HSE 4.4 V8 Chawton White
I have 20" wheels and 255/50/R20 Nokian Outpost APT tires.
I checked tire pressure today and to my surprise it was set to 30PSI for front and 36 - for rear. The sticker (below) says that it should be 36 for front and 44 for rear.
Wanted to check with the community - is it OK to set 44PSI with these Nokian tires for rear wheels? Nokian's site does not say anything but other tire shops list 51PSI as max inflation pressure.
Post #699518 5th Sep 2024 5:40am
Gsxr1250dave
You should fine as its the specified tyre pressure fir context I run all mine at 40psi on genral grabber a/t with no issues
Post #699521 5th Sep 2024 7:06am
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
My lable from my 2012 UK TDV8 L322 below, 33F 36R, although I run mine about 31F 33R on my 255/50 x 20s as it's slightly more comfortable on our crappy roads.
Maybe US tyres are different compounds requiring higher pressures, but does seem a bit hard.
I'm guessing your lable is for fully loaded pressures, not normal driving ones which are probably quite a bit less.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #699522 5th Sep 2024 7:10am
JayGee
I suspect those pressures in the pic are for when the car is fully loaded with 5 people + their luggage. 2012 TDV8 Vogue (L322)
Post #699524 5th Sep 2024 8:05am
invisible999
That's what I think too, but does this apply to my case as well?
Post #699563 5th Sep 2024 3:34pm
JayGee
If you have 5 people in the car + luggage then yes. If not use the lower figures as suggested by Andy. If you are going off-road with AT tyres you can lower them even more to improve grip. 2012 TDV8 Vogue (L322)
Post #699565 5th Sep 2024 3:55pm
invisible999
What would be recommended pressure for off-road driving if 'road' is basicially small rocks/dirt and does not have sand?
Post #699567 5th Sep 2024 4:12pm
AndyRoo
I'm not sure to be honest because the 50 profile sort of limits the bead hold. We used to take our P38s down to 15 in Dubai for sand but they were on 255/60 x 18s but drove with out too much hard cornering on the dunes.
On a 50 profile I'd be worried about going less than 20 for fear or the tyre coming off the bead.
A Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #699572 5th Sep 2024 4:43pm
