Hi vs322, did you get anywhere with this issue? I've got the same issue - rear washer not working. I've tested and replaced the pump (which was faulty), and checked the fuse in the glovebox fuse panel. But still nothing when pushing the wash switch forwards.
The wiring diagram shows (attached) shows that the front and rear washers each have their own individual fuses (38P & 43P), which are easily found and even labelled with the matching numbers in the gloxebox panel. The diagram also shows each has it's own relay (17P & 18P), bur I can't find any relays anywhere labelled accordingly....
It MUST be the relay, but where on earth are they.....
Any help would be really appreciated, thanks
Current - 2010 Range Rover 4.4TDV8 Vogue SE Auto
Current - 2014 Defender 90 XS 2.2
Previous - 2020 Evoque D180 R-Dynamic SE Black Auto
Previous - 2016 Discovery Sport Auto 2.0 TD4 HSE Black Auto
Previous - 2010 Freelander 2 2.2 Diesel Auto
