Home > Maintenance & Mods (L322) > AC hoses connected to the compressor are stuck
blueRR2006
United States 2006 Range Rover HSE 4.4 V8 Buckingham Blue
Anyone experience stucked hi/lo ac hoses to compressor?
Replacing ac compressor, but after taking bolts out, unable to disconnect/separate hoses from compressor.
Thanks in advance 2006 Range Rover HSE 4.4L Jag Engine/ Buckingham Blue
Post #698956 27th Aug 2024 7:03pm
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
If the hose allows, try rotating it by twisting it backwards and forwards until you get movement, then lift at the same time.
Post #698963 27th Aug 2024 9:57pm
blueRR2006
Yes that worked, along with lifting up with a slightly angeled interior panel wrench. Thank you!!!!
Now trying to locate the ac compressor mounting bracket bolts. I have the driverside wheel off and splash guard, but don't see how to get to those two bolts 2006 Range Rover HSE 4.4L Jag Engine/ Buckingham Blue
Post #698981 28th Aug 2024 12:18am
