![]() | Home > Maintenance & Mods (L405) > Lowering the subframe slightly - propshaft off ? |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1458 ![]() ![]() |
So looking at the logistics of doing the ACE pipework. Haylands took the full subframe off ( here ) whilst in this video, the subframe was partly lowered and hanging from the unwound bolts.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8525 ![]() ![]() ![]() |
I would think there is enough room for the prop to drop some amount, if it's enough to change the pipes, that's a suck it and see job... |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1807 ![]() ![]() |
If you can't remove it from the rear diff, remove it from the transfer box end and drop the shaft with the subframe/diff assy |
Thanks chaps, like you say, I’ll just wing it. V8 or else ... |
If it isn't then take out the nearside bolts and drop it on a jack a bit more that side, just be careful and don't catch anything... |
Oh, good idea. V8 or else ... |
Just to feed back, this worked and worked very well. New rear ace pipes installed and rear coolant cross over coolant metal pipes now replaced with a single run of hose.
Top job, should be sorted for a few years now... |
NoHandSignals Member Since: 28 Aug 2023 Location: MI Posts: 28 ![]() ![]() ![]() |
Did my rear ACE pipes With the fuel tank in position and by only dropping the rear subframe a couple of inches, leaving it hanging on a few threads like you did. I did this with the car on a ramp though!
