Home > Technical (L322) > Seeking CANBUS experts |
btbtbtbt318 Member Since: 10 Aug 2024 Location: Victoria Posts: 10 |
Hi All,
18th Aug 2024 9:18am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2385 |
Have you disconnected the PCM? |
19th Aug 2024 12:03am |
PCM - powertrain (engine) control module. However unlikely to cause the short circuit when switching on accessories but the BCM or whatever the main fuse box is called in your model sounds more likely.
19th Aug 2024 11:07am |
This for MY10-12 might be of some use.
19th Aug 2024 11:12am |
Thanks Graeme.
21st Aug 2024 9:31am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8065 |
IIRC "Invalid data from DSC (ABS) module" is a "standard" always there fault..
21st Aug 2024 9:56am |
I assume that you have the e-diff introduced for the 4.2 SC but not the TR system which was introduced in MY07 and that your suspension module has a single connector, being pre-TR. Your diff housing should be the same as MY07 onwards for which the e-diff was optional. |
21st Aug 2024 10:11am |
I am pretty certain I don't have the E diff despite being a supercharged. Housing looks like the attached and there are no electronics, solenoids or anything around it that I can see:
30th Aug 2024 9:51am |
Well I've sourced a RQT500181 module and plugged it in, no particular change to the problems I'm having although I'm not 100% on whether it's 100% compatible or not.
13th Sep 2024 8:50am |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 413 |
Have you calibrated the steering angle sensor?
13th Sep 2024 9:40am |
Hi Jon,
13th Sep 2024 10:12am |
It's not always just lock to lock on vehicle start-up, if you have a LR specific tool (like a GAP IID or similar) then put it into learn mode for the steering sensor calibration.
13th Sep 2024 1:04pm |
