Home > Technical (L405) > Losing oil - but when and where. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3858 |
When I do an oil change using the suck it up method I never get over 9L and as the service required warning came up (oil last changed in early June) I checked the oil level - its down a bit. When I read all the posts relating to partial regens it should be up as I do a lot of short journeys (long one to clear DPF every week) and so diesel must be added to the oil thereby increasing its volume. So why does my car do the opposite, no drips on the drive, never any smoke from the exhaust must be something else - but what? Geoff |
15th Aug 2024 10:23am |
baz000000 Member Since: 01 Apr 2022 Location: Shropshire Posts: 141 |
Have a look at the base of your oil filter area. It is common for the oil cooler to leak and there can be a lot of pooled oil there. Then any excess will run down the back of the engine. You would normally also see oil drips hanging from the back of engine undertray blots in a severe case |
15th Aug 2024 1:03pm |
