Home > Technical (L322) > Non Start situation, check this first
Mikey
3rd time I've seen this now. Ignition on, all OK. Click frommstarter solenoid but no crank
Once you've established the engine isn't seized and battery isn't flat, check the main terminal junction in the rear of the OS wheelarch
Post #684049 27th Jan 2024 5:09pm
Stuart-
Is that actually in the wheelarch, exposed to the elements? 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1982 Rolls Royce Silver Spirit in green
Spiffing wheel centre caps, L322 sill repair panels, etc
Post #684217 29th Jan 2024 12:29pm
LFREE22
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Mikey, I'm having this problem and would like to rule this out before I replace the starter...
However I'm having trouble locating it. Is this inside the boot beside the fuses, or do I need to jack the car up and remove the arch liner to get to it from the outside?
Any help to find it would be appreciated. Cheers
Post #698067 14th Aug 2024 3:42pm
mjdronfield
I’m guessing it’s in the rear of the front offside wheel arch.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #698072 14th Aug 2024 4:31pm
