Home > Maintenance & Mods (L405) > Oil Service cost
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
Oil Service cost
I recently booked my L405 SDV8 in for an Oil Service with my local dealer. When booking I quoted the fixed price as listed on LR's own website (£247.4Cool. This was agreed with the person taking the booking.
The service was undertaken yesterday morning and when competed I was handed an invoice for £450!
I let it be known that this was not the agreed price and referred to LR's stated price on their website. There appeared to be some confusion within the admin team at this point and they said they would need to get the parts department to review the charge.
I left the dealership without paying and now awaiting a correct invoice to be emailed to me.
Even at £247 it seems expensive so i may consider undertaking all future oil changes myself. 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #697989 13th Aug 2024 2:42pm
Does it state what work was actually done ?
In general, I'd expect a main dealer to do whatever the schedule says for the age/mileage and not just the oil & filter.
Post #697995 13th Aug 2024 3:18pm
Buz1500
My car didn't need a service as such, I just wanted an interim oil change and requested as such. It's not due for its next service until early next year, based on LR's own maintenance schedules.
Stated work was oil & filter replacement. 2019 L405 SDV8 Autobiography
Post #697996 13th Aug 2024 3:22pm
In that case, completely OTT.
£100 in parts and an hours labour ?
I did my first one on mine as the indicator came up & I'm in the middle of nowhere in France for a while. It's the easiest oil change I've ever done on a vehicle.
Post #697999 13th Aug 2024 4:26pm
Gremlin500
@Buz1500, as Alistair has said, it’s super simple to DIY, and only about £30-£40 per change once you have the gear, which you will easily get the money back for the first time you do it. There’s loads of info on here to show you what you need o get the oil sucked out & change the filter, plus the WM up above to help you. LR MD’s are a total rip-off, it’s only 1/2hr job, and most of that is standing around waiting for the pump to do its thing. :thumbsup:
Post #698001 13th Aug 2024 4:46pm
Rob99
Just did my first oil change with a suction pump. Super simple and, even including buying the pump and 36mm socket, was less than £100. Next time it will only be around £60.
Worth having a read through this thread too........
https://www.fullfatrr.com/forum/topic70436.html 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #698002 13th Aug 2024 5:07pm
Buz1500
Thanks for the replies, certainly food for thought. 2019 L405 SDV8 Autobiography
Post #698018 13th Aug 2024 8:10pm
Gremlin500
Cheapest way I could get C1 5W30 LR oil was Smith & Allen £63.88 for 20L, about £70 delivered. That does 3 fills for my TDV6, plus 2L left over for top-ups (which it never needs). So £40 a time including filter. You will only get 2 fills, but still around £45 a go DIY ( once you have the pump etc).
I already had a compressor so bought the Neilsen 9L vacuum thingy for about £90, a bit slow with my weedy little compressor, but gets the job done in about 20mins. Go for it! :thumbsup:
Post #698023 13th Aug 2024 8:49pm
garyRR
I don't use the Smith & Allan oil becuase it doesn't have the JLR approval (doesn't mean it's by any way inferior however; just my personal preference).
I use Petronas 5000 FJ which does have the JLR approval. I use the Draper oil extractor every 7,000 miles. Every alternate service is a full service with air filters, pollen filter and fuel filter. JLR made servicing on these cars so easy, that even a full service you can do in 45 minutes (but obviously they won't tell you that).
Petronas 5000 FJ is available from Opie Oils at around £50 for 10L. 2015 Range Rover Autobiography 4.4 SDV8
Post #698028 13th Aug 2024 9:59pm
Gremlin500
@GaryRR:
From Smith & Allen website:
Momentum C1 5W30: “ACEA C1 (2016)Ford WSS-M2C934-BJaguar Land Rover ST JLR.03.5005”
So it does meet JLR Specifications. :thumbsup:
Post #698029 13th Aug 2024 10:14pm
garyRR
Meets, yes. Approval, no.
The two are different ‐ one they have paid a laboratory to test it meets the required specification and obtain approval, the other is simply made to the specification, but without an independent test/approval. 2015 Range Rover Autobiography 4.4 SDV8
Post #698031 13th Aug 2024 10:18pm
Gremlin500
I guess that’s possibly only really important if folks have a JLR Warranty, rather than 3rd Party.
The difference in price is what approved suppliers had to pay JLR for “Approval”
If it meets the spec, it meets the spec so “Approved” is no better IMHO.
Given my car is 2017, as soon as my C1 5W30 is used up, I plan to switch to C4 5W40 in any case.
Post #698032 13th Aug 2024 10:43pm
JayGee
I used Petronas last service. The viscosity and ash content are the only important factors with this oil and I don’t need JLR ‘approval’ to assure me that S&A’s C1 has this. Any details of what JLR’s actual testing involves in order to get approval? 2012 TDV8 Vogue (L322)
Post #698038 14th Aug 2024 7:59am
dingg1
Jlr won't do any testing on their approved oils.
Oil co talks to jlr, we would like to be your approved oil supplier, these are the tests were going to carry out, we will pay you x amount to be your approved supplier.
Ie its all marketing Censored .
As long as the spec is met it doesn't matter one jot whose name is on the label
Post #698039 14th Aug 2024 8:11am
JayGee
Assumed it was so…. 2012 TDV8 Vogue (L322)
Post #698041 14th Aug 2024 8:58am
