Home > Technical (L322) > Low battery Smart key warning 2012 L322
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
I've always had issues with Duracell so use energiser , sometimes takes a couple of start/stops for message to clear though .
Post #662243 18th Apr 2023 8:41pm
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Just thought I would I post this up just in case anyone had problems with the low battery warning still showing after key fob battery replacement. I changed mine today and it was still showing battery low on the dash, so I pressed the lock button on the key fob with the engine running and the warning along with yellow triangle went straight off. Hope this helps anyone who still gets the warning after battery replacement.
Post #697924 12th Aug 2024 6:49pm
muppet
United Kingdom 2012 Range Rover Westminster 4.4 V8 Barolo Black
I did try this yesterday ( locking the doors with the engine on ) and when I use the key buttons, it does that "error" bleep and unfortunately the warning message and yellow warning triangle still appears, I think I have now got use the warning beep and warning sign.. any other ideas welcome... I need more help than most...sorry !!
Post #698042 14th Aug 2024 8:21am
Barmybrummie
Hey Muppet I did it with drivers door open, engine running and after I pressed the 'ok' button to clear message so the yellow warning triangle stayed lit, then pressed the lock button. The key fob was on my knee so I'm not sure if it was because it was near the sensor down by the steering wheel column. Worth a try.
Post #698051 14th Aug 2024 10:48am
muppet
Thanks BB, tried all those but to no avail, appreciate the suggestions though...cheers !! I need more help than most...sorry !!
Post #698129 15th Aug 2024 12:18pm
Barmybrummie
That's rather bizarre how it worked on mine and not yours. I only guessed it by pushing the the lock button and it worked. You could try pressing other buttons if you not done so already.
Post #698132 15th Aug 2024 12:39pm
AndyRoo
Scotland 2012 Range Rover Westminster TDV8 Fuji White
I know this doesn't help but I always change the car key batteries sat in the car, and check it's working fine before I get out. Been caught out a few times over the years.
Usually it's the battery not seating properly so it's like struggling on power, a bit of corrosion or lost spinginess in the contacts perhaps, try spinning the battery in it's holder or wipe the contacts with a bit of dry nylon scrubber & contact cleaner.
A. Fuji White / Jet 2012 4.4 TDV8 Westminster
Post #698136 15th Aug 2024 12:53pm
